Dual nozzle set-ups
TURBOV6
"SECRET PARTS"
Staff member
I have one of the newer SMC kit waiting to get installed and was woundering if it would be better to get dual nozzle or the single is good enough?
And is it better to locate the nozzle on the lowest part of the inlet pipe? I also have a BOV. Will this be a problem of alcohol spraying out?
Doesn't the alky work in conjunction with boost? And doesn't the BOV work with vacuum?
Problem is when you lift and close the throttle blade...poof out of the blowoff valve comes whatever is left in the up-pipe.
How much..dunno..dont use a BOV
Do the single..add the extra line as neeed.
Good luck
