Dual Port Internal wastegate - CO2 pressured?
Blazer406
Mechanical Engineer
Is there anyone running a dual port internal wastegate actuator and hooking it up to a boost controller like the AMS 500 or AMS1000 and using CO2 to control it?
Robert Wilson made one from a pneumatic cylinder that apparently worked ok.
the stock style will have issues leaking CO2 around the rod seal in my opinion.
Bob
I seem to remember a thread showing his fine craftsmanship..... there are some factory stock dual port wastegate actuators.... and I know the aftermarket has recently been talking about a new one.... maybe turbosmart?
The turbosmart one below is a single port.... but I seem to remember there was an "upper" limit to what boost you can run if you put the spring too weak to get your "launch" boost down. I am guessing this is where the CO2 control and dual ports give you that extended range.... like 5 psi spring and the ability to go to 30 psi on the top side.....
http://www.turbosmartusa.com/news/new-internal-wastegate-actuators-are-coming
http://www.full-race.com/store/turbos/borgwarner-efr/efr-dual-port-internal-wg-actuator.html
http://www.racingpartdepot.com/servlet/the-808/OBX-DUAL-PORT-INTERNAL/Detail
those all look cool. With the CO2 the rod-side seal is important, since thats the balance side (equivalent to the "top" on an external gate). Once you have a good dual-port actuator, there are a LOT of cool things you can do with CO2. (not just the AMS stuff)
Bob
I bought several years ago... a turbosmart eBoost2 boost gauge/controller. I have talked about going external and CO2 controlled, but this looks tempting to try and see.... and yes.... I agree.... how you seal the rod off would be important.....
I have a customer that has an AMS 500 but is still running the stock internal wastegate.... so I need options there as well....
let me know if you wind up getting any of those actuators, I'd like your impressions.
Bob
I guess if you had rod seal issues it would really go through the CO2.......
Too bad we don't have a push to close style........ then the rod seal would not be an issue....... you would (probably) only need to pressurize the back side of the diaphram which would be a closed cavity...... no rod to protrude through the pressure boundary.
yeah, setting up a push type actuator would be cool. use the diaphragm housing from an external gate, and mount it on the other side.
Could be some interesting ways to configure that.......
Bob
I just ordered one of the middle ones, I have some really cool ideas I want to fiddle with this summer.
Bob
Here's a thought... Why not reverse the arm on the wastegate arm so you can pressurize the correct side of the acuator? Do this all the time on air shifters on motorcycles...
thats a cool idea....
Bob
You can't follow monkeys and expect to be anything but bananas.. ;)
I've tried a lot of different things over the years that I never showed others.. and they actually work.
Interesting.
Bob you still have that actuator I sent? That was a dual port. No?
RL
yeah, I never had the chance to install it. I never got the chance to fabricate a mount for it.
Bob
Got my AMS500 on its way, any chance for more input about dual port internal actuator?
Thanks !
