blackbuick87
Senior Member
- Mar 11, 2002
I am about to order one. I have a few q's first
1. How long did it take you guys? I know several good welders and wont be doing the welding but will do all the prep work myself.
2. Did you follow the procedure on gnttype.org or did you use your own? I think the most difficult part will be cutting and welding the IC to match the neck. Why the hell didnt Duttweiler make it so they would match up, or make his longer?
3. I have seen several members say "I gained 2psi, or I gained 4psi". How can you gain boost by removing a restriction? Or do you mean the neck allowed you to run more boost without getting knock?
TIA
TIA
