SignUp Now!Originally posted by Mac in SD
Correct. The Duttweiler pump kit comes with the (long) gears, and you use a standard pump front cover.
Dave, I just used the gasket, and no problems so far. Also, to check gear clearance, I assembled it in the cover before mounting it on the engine and checked for play (and binding) with the shaft. As far as the bypass adjustment, I followed the instructions that came with it.
Originally posted by gnxtc2
The V6 longer gears are the same ones that are used in a Buick 455 front cover as stock ones.
I just sprayed some of that copper spray on that thin gasket and sealed perfect.
Billy T.
gnxtc2@aol.com
Originally posted by HighPSI
Are you sure? The reason I ask is because I have used a HV cover with Duttweiler oil pump. I had to use HV Buick 455 gears. The problem I ran into was the shaft for the big block was much longer and had to be shortened.
Originally posted by Nojug
So you can use a HV front cover but there would be no real advantage correct?
