SignUp Now!Originally posted by kshef
is this a worthwhile investment for a stock 87 GN.....is i good for 30hp???
thanks
Originally posted by UNGN
Yes, its worth the investment: $70 for the Neck, $30-50 to have it welded on and about 2-4 Hours of handwork.
30 HP is at high boost (big turbo, injectors) on a stock GN its worth maybe 20 HP max, because you will run out of injector/turbo.
It is worth about 1.5 to 2 psi without touching the wastegate.
Originally posted by TT/Ameasap
Is that detonation free though? It might give you 2psi but wouldn't you have to turn the boost down just that much?
My TTA can run 17psi of boost at 0 KR. If I did this mod and no other change, I should be able to run 18.5-19psi of boost 0 KR if I read what you are saying correctly.
Bo
