SignUp Now!Originally posted by sixgun86gn
Quite Impressive.Makes me wonder what a properly tuned progressive setup could do on a motor like mine.Too bad I have traded the motor for another car and can't play with it anymore.Might be interested in testing it out on the TA aluminum motor that is going to replace it though.
Originally posted by Swede2
I went in and checked some of the supercars torque numbers...
For example Pagini Zonda, Ferrari Enzo and F50, Lambo Diablo, Koenigsegg all have less torque than Julios car. Thoose cars are mostly V12, and not V6 hehe...
Wanted to tell you guys about it just to make you realize how much power it is in it now
Daniel
Originally posted by Razor
Nick,
TE67 w/69 trim, 210/205 Reed flat tappet cam, single chain, ported intake, 160 stat, ported heads, FM IC, 65 lb inj, ME-r at 18 degree base, 3600 9x11 Billet, walbro 307, THDP, stock 58 MM TB, stock pistons, stock bottom end, and an alky kit
Basically a little cam, heads, bigger turbo.. open the airflow on the motor.. it makes the numbers. Nothing special.
Just pay attention to what its telling you. Learn from that. Make adjustments that affect it in a positive way. Done.
I think 28-30 PSI on this bottom end it will scatter. I may find out Friday/Saturday. I'll see how the motor responds .. and make the call.
And your tranny works flawless so far ? How old since rebuild ?
Daniel
