89mulletbird
- Jun 24, 2004
Stock TTA block with 70k miles on it
Champion iron heads
210/215 roller cam
RJC powerplate
THDP with cat test pipe
6152S journal bearing @ 22psi
Turbotweak alky chip
Dutt IC neck
Razor's Alky kit
60lb injectors
Not sure what would be the next step to increase power? I was running 12:1 AFR on this run, which is about as lean as I dare to go. I'm thinking a larger, newer turbo. Mine is rated at 630HP. I'm also still running a MAF.
Champion iron heads
210/215 roller cam
RJC powerplate
Dutt IC neck
Razor's Alky kit
60lb injectors
