If you are to Dyno test your car on a chassis dyno, what gear do you put it in.
The idea of the tranny is to use gearing to multiply the torque transfered to the wheels which again gets multiplied by the rear.
So with the torque then calculated into horsepower by virtue of the RPMS, how do you not get inflated numbers?
Even if 3rd is 1:1... your rear end is still multiplying it some.
