Dynomax race bullet mini
What the crap is that?? Sounds like there is a crack a mile wide in drivers header & a power steering pump that hasn't been filled since 1987. :eek:
its just a 3" straight pipe from the dp with no cat or muffler until i have a chance to put the bullet mini on
No I meant if anyone wanted to hear my exhaust, the Hookers with Aero Chambers. Was being sarcastic as everyone hates the drone of the Aero Chambers especially me.
Not mine nor do I know the guy, but he claims 800hp. Sounds pretty mean to me.
cant be any worse than my single shot with no muffler.. drrroooooone
If you guys have dumps off your DP's, you can put a washer on the two studs on the bottom and put the cap back on for tuneable sound. I have been doing that foe years.
I am looking at the race bullet for less weight and not a totally wide open sound
Here is a vid last year of my car and little washer trick.
No dump on mine
Still riding around with the muffler in the floor board, aint had time to install it yet
Thanks.
I just got it from Summit 20 minutes ago. Sounds GOOD at idle. I got video on my Iphone, but the sound seems backwards. Bullet sounds louder and no exhaust sounds softer on the phone. It is the exact opposite in reality. Here it is tho. Oh, ignore the ticking from the loose clamp.
Sounds like it hollows it out when its on. kinda what im looking for but u have a full legnth bullet where mines a mini. Only 7" long
Your cars are loud compared to mine. I have a 3'' single exhaust that i had a local muffler shop make for me using a Hooker dual exhaust piping to make the bends in the pipe which is 3''. I use a 3'' inlet and outlet Moroso spiral flow muffler at the end of the 3'' ATR downpipe,then into the 3'' mild steel pipe the muffler shop made,then into a 3'' Hooker Aero Chamber aluminized steel muffler,then i use the Hooker 2 1/2'' exhaust tail pipe that goes over the rear axle and exits behind the rear tire on the passenger side. I wanted the muffler shop to make me a new 3'' tail pipe but they couldn't do mandrel bends thats why i used the original Hooker tailpipe.
The car is not loud at all and no drone. I can pull along side the police and they won't notice the car because of the exhaust noise. There is no restriction of the exhaust flow the car absolutely flies.
Sounds restrictive & heavy but hats off to u if its not
I weighed my piping/muffler and hardware = 52lbs
New system is going to be 10lbs
-42lbs isnt too bad.
