ROMPESTOMPER
- May 10, 2010
Hey guys my name is Jimmy and although Ive read a lot of threads here I haven't signed up until know. First off, out of all the forums Ive been in, this one has by far the most factual information about E85.
I'm sorry I don't have a Buick But I know you guys will have the best factual information I need to complete the 4 projects Im currently considering the switch to E85. I have a list full of questions I hope you guys can help me with.
1. Project number one is a 77 Southwind jet boat.
bbc 468 nitrous motor
low end is a 4 bolt main gen 4 block, forged steel crank ( nothing special)
eagle h beam rods, probe 11-1 compression forged alum pistons.
total seal rings I think.
Top end, rhs 360 cc aluminum heads race ported with all the best top dollar component's, valves, springs, keepers, retainers etc. Howard's solid roller hi performance lifters ( 10 x better than most) beefy push rods unsure on brand, I'm in in my office. 720 lift custom grind solid roller cam (big) Don't have the specs with me. Jessle shaft mount roller rockers. Aeromotive vacuum pump. The intake is a piece of art. It started as a weiand hi ram tunnel ram with the top machined off and a 871 plate welded on to adapt the 2' up and 3' forward blower riser and machined for the nitrous injectors. On top of that is a bds bug catcher-throttle body. The intake was also machined at the lower runners for my threaded 72 lb bosch injectors controlled by a fast xfi ecu. Rite now its has a 300 shot from nx express and it runs on 110 octane at all times. This motor is new and last sat I finally got a good tune on it. Long story It was dynoed last year but I lost the tune because of a wiring issue. It put out 740 hp at 6700 and 1050 on the nitrous at a similar rpm range. I'm running a fast duel sync distributor witch I recently got to finally work after sending it back 3 times. My fuel system consist of all an hoses and ends -8 from 2 tanks to a y block to a fuel water separator to a 100 micron aeromotive filter then to the areomotive a-1000 fuel pump good up to 1300 hp with my app. I'm also running a big oil cooler and a bypass over sized oil filter. Keep in mind that my nitrous system is a bit advanced meaning The nitrous lit only injects nitrous, the ecu adds the 30% fuel from the injectors not the nitrous nozzles.
So now that you have a history on my motor here are my questions
1. can you run E85 with aluminum fuel tanks, I head they corrode easy.
2. with my 72 lb injectors they are never at full duty cycle even with the n20 but with the switch I know it will be too close for comfort. Will 120 lb injectors be enough. Max hp of 1300 Also because of the added performance of E85 I may easily go from a 300 shot to a 400 shot of nitrous. a 500 shot will be the max rating of my fuel pump but may upgrade that if needed but don't want to buy injectors twice.
3. How does nitrous react with E85?
4. will I need to go bigger than - 8 fuel lines. I was thinking of converting the fuel line to -10 from where the 2 tanks merge to the y block to the fuel pump. Do you think that is necessary?
5. Can I add 2 stroke premix oil (Small amount) to the e85 to lube the motor and help with the corrosion of the aluminum
6. How long is the E85 shelf life?
7. Is there ant additives for E85 to keep it stable for storage and keep it from separating.
8. I also heard that it can also eat through aluminum fuel rails over time is that true? Some hard anodize them.
This is a long first post! Thanks for your help. I still have 3 other projects I still need help with but didn't want to overwhelm you guys rite off the bat.
I will post some pictures if some one will tell me how!
