I think I have some theory's to why these work for some of us and not for all of us, including Imports I've been reading issues about.
Here is a link to our E3.42 plug with some specs
E3 Diamond Fire Spark Plugs E3.42
E3.42 plug reach - .439_______Other Plugs = .460. This means the E3 is somewhat of a Non Projected tip plug vs the traditional plugs. This means the electrode will stay cooler since it's closer to the top of the cylinder vs the traditional plugs. This is a huge reason why big psi engines like non projected tip plugs because it lessens pre-ignition and detonation. Point to E3 here in FI engines.
E3.42 has the resistor in the plug, this is surprising to me that some of us can fire it without blow out at high boost along with the gap. I'd almost rather see this plug as a non resistor and eat up spark plug wires over time but it's firing 25psi for me so I'll take it. Neutral point for us but doesn't help those with weaker ignitions.
E3.42 has a .040 spark gap, this is probably the main reason many Imports and some GN's say this plug sucks. I looked up the gap the Evo (E3.48) etc Imports run and it's still .040. I can tell you that with my Talon at 30psi and with a Crane Fireball, I've got to gap traditional plugs to .025 now to keep it lite the whole run.
So, I'd take it to the bank that your GN better have a newish coil (mine is pretty new) with these plugs or you're going to have trouble. I've had the boost up to 30psi, when I took off the FMIC, and it was not only firing but might've kept going.
These plugs will really shine if any of us go to the Bob Bailey COP. That will probably be the main component to making these plugs work for ALL of us and all of the time.
I'm going to stick with these and I'll report back since I plan on upping the boost to 26-27psi when I add another Alky nozzle this Spring.
