So , any of you H/A guys running E85?? I'm looking into doing one or the other. (E85 or Alky) Just wondering what experiences anyone has had with E85 on a H/A. Alot of info on the Alky, but not so much on E85 in a H/A. Not looking for a track only car, mostly street driven with the occasional run to tune and to make me grin.:biggrin: Post up and share your ideas and thoughts.
In round numbers;
For every 10F decrease in temp, you gain about 1 psi equavalent in density.
For each 10F decrease, boost level will drop, and the WG compensates by keeping it constant (Compounded boost increase).
For every lb/boost you gain about 6 HP.
If you have aspirations of running E-85, I would add the alky.
E85 will definitely cool the charge prior to entering the chamber + add octane.
At 20PSI boost (arbitrary number), the intake charge is still around ambient + 200F (Give or take a few degrees
), so, why not knock that temp down a little with the alky, before it starts its path into the intake port.
So, You add alky and turn the boost up +10PSI (example), you get 60HP + net effect of temp reduction.
JMO
It's not uncommon with these HA cars to cruise around on a +90F day and see intake temps of +140F
No actual 100% E85 / conversion experience, but hope this helps.
