Eaton posi after transbrake launches
GO FAST
Well heres a pic of my eaton 30 spline posi unit after 14 months and well over 80 transbrake launches . I pulled the cover for a routine oil change and inspection and found two teeth broken on a side gear. I actually thought it would be worse after the torture I put it thru.
It is not much worse than a stiff detroit locker.
I had a Pro Trax that drove like a spool until it broke two weeks after the warranty was up. :(
if you drive with et streets a spool inst that noticable, unless you are trying to paralle park
