Originally posted by REDS HOT AIR
well since my last outting i've....changed to n/a v6 front springs, removed front sway bar, put in 90/10 shocks notched frame and moved wheel wells in and have 28/12.50/15 et streets under it, i've gone from my hooker d/p and duel 2 1/2 exaust to atr 3" external d/p and single shot exaust, i stepped up to a 208-224 cam, i've done alot more port work on the heads, and i've restalled my converter from 2800 to 3400, not to mention the step up to 75# injectors
my 11.16 @ 127 pass was coming out off idle with a 1.84 60 ft and no tire spin and just about the 1/8 mile the car started popping out the intake from being lean with 02's reading 640's and that was at 23-24# boost
so now im looking at not being lean and having the boost up in he upper 20's depending on if ol walbro will keep up..LOL
and im nowhere near planning on coming out off idle this time..![]()
i've got a gallon of vht and a spray bottle ready to go![]()
think its possible ???
Where do you get the VHT from? Jegs i assume....i never knew you could use that stuff like that.....
