who in the chicago mods the ecm for bigger injectors, what does it usually cost, what is actually done for the bigger injectors and why, also would consider buying one all ready done
Originally posted by tom j who in the chicago mods the ecm for bigger injectors, what does it usually cost, what is actually done for the bigger injectors and why, also would consider buying one all ready done
Chicago area?, no one, unless you consider MI, as being in the Chicago area. FullThrottle does the mod, and they're in MI.
It involves changing the *Power transistors for the injectors*, and adding sensing resistors, as I understand it.
There's always a change of getting taken when buying used, unless you know the seller. My advise is buying a used ecm, installing it in your car, and running it, so you know it's good, and then having it updated.
