ECM question
well since no one else has chimed in i am pretty sure i am correct on this one . someone correct me if i am wrong but . you need to match up the numbers on the ecm this i know. but you will need to use your prom chip from the turbo car to run in that ecm. look at your numbers on there and see if they match if not no dice!
Don't have one handy to match up numbers to. I have a chip to use and I can get a monte ecm for free.
99% sure this is the ecm number you need. i assume this is an 86 or87 GN? this is the number you need#1227148 ECM. if thats not the ecm out of the monte you can get one out of junk yard from an old gm front wheel drive car just needs to have that number on it an old buick or olds will have this number i believe pontiac too. but thats the number you need to look for and your golden
NO- It doesn't show on the list...
86-87 ECM
GM #1227148
Here is a listing of all that use it:
Note: Turbo Regals use different chips; don’t use the chips from these cars on you GN!!
1989 PONTIAC FIREBIRD TRANS AM V6 3.8L 231cid GAS FI T Engine VIN = 7
1989 PONTIAC FIREBIRD TRANS AM GTA SE V6 3.8L 231cid GAS FI T Engine VIN = 7
1987 BUICK REGAL GRAND NATIONAL V6 3.8L 231cid GAS FI T Engine VIN = 7
1987 BUICK REGAL LIMITED V6 3.8L 231cid GAS FI T Engine VIN = 7
1986 BUICK CENTURY CUSTOM V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK CENTURY ESTATE WAGON V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK CENTURY LIMITED V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK CENTURY T-TYPE V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK LESABRE CUSTOM V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK LESABRE LIMITED V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 OLDSMOBILE CUTLASS CIERA S V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 OLDSMOBILE CUTLASS CIERA V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 OLDSMOBILE DELTA 88 ROYALE V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 OLDSMOBILE DELTA 88 ROYALE BROUGHAM V6 3.8L 231cid GAS FI N Engine VIN = 3
1986 BUICK CENTURY V6 3.8L 231cid GAS FI N Engine VIN = B
1986 BUICK ELECTRA PARK AVENUE V6 3.8L 231cid GAS FI N Engine VIN = B
1986 BUICK ELECTRA T-TYPE V6 3.8L 231cid GAS FI N Engine VIN = B
1986 BUICK ELECTRA V6 3.8L 231cid GAS FI N Engine VIN = B
1986 BUICK LESABRE V6 3.8L 231cid GAS FI N Engine VIN = B
1986 OLDSMOBILE 98 REGENCY V6 3.8L 231cid GAS FI N Engine VIN = B
1986 OLDSMOBILE 98 REGENCY BROUGHAM V6 3.8L 231cid GAS FI N Engine VIN = B
1986 BUICK REGAL GRAND NATIONAL V6 3.8L 231cid GAS FI T Engine VIN = 7
1986 BUICK REGAL T-TYPE V6 3.8L 231cid GAS FI T Engine VIN = 7
found info here...
http://www.turbobuick.com/forums/junkyard-dogs/295169-junkyard-parts-donor-list.html
