Having problems with ecm resetting under high rpms and high load..all data and info goes to zero when this occurs.Its like if ignition were to be cut off..but thats not the case.
Ignition and Battery wires confirmed to have power when this condition occurs at the ecm terminal.
With direct scan I can see all data going to zero and then coming back up.Have swapped ecms,plugs,wires,ground straps at engine,running out of ideas...
My next test today is a spare coilpack/ign module..but fearful thats not gonna fix it.
Any ideas would be appreciated
