mikestertwo
- Sep 13, 2006
I re-read your original post and you mentioned the check engine light "flashes on and off like mad". That is a check sum error in the computer. Your problem is computer related.
SignUp Now!whenever this surge happens the car never dies completely, I take my foot off the gas and it cuts in and out for mabye 2 -3 secs, check engine light flashes on and off like mad. and sometimes even resets the computer whenever it happens. my scanmaster readings will flip out and give me a bunch of different error codes and then go back to 00 once its done having an aneurysm lol what is happening?!?!?!
Sounds like the ECM is intermittently loosing power.
 I went ahead and bought some 60s w a turbo tweak chip, in case it was a bad injector, plus I didn’t know what kind of chip I had in the car so it didn’t hurt to install those. My Orange ECM wire was re-routed a while ago and runs up the fender and doesn’t touch the heads/manifold, neither do the alternator wires.. the fuse link for the ecm is fine, I replaced the old TPS and adjusted it properly along with the IAC.  I’ve wiggled every wire/relay in the car and it doesn’t cut out. It only seems to cutout when it’s in gear. Also I replaced the ECM.. probably didn’t have to but I thought given the symptoms, I could’ve fried the computer... but that wasn’t the case. Oh well ♂
 I went ahead and bought some 60s w a turbo tweak chip, in case it was a bad injector, plus I didn’t know what kind of chip I had in the car so it didn’t hurt to install those. My Orange ECM wire was re-routed a while ago and runs up the fender and doesn’t touch the heads/manifold, neither do the alternator wires.. the fuse link for the ecm is fine, I replaced the old TPS and adjusted it properly along with the IAC.  I’ve wiggled every wire/relay in the car and it doesn’t cut out. It only seems to cutout when it’s in gear. Also I replaced the ECM.. probably didn’t have to but I thought given the symptoms, I could’ve fried the computer... but that wasn’t the case. Oh well ♂really?did fuel pressure rise 1to1?did you ohm the wires and ground?So I’ve gone around and done everything recommended by you guys, no luck
which codes?my scanmaster throws codes at me but the car never completely dies.
Different codes each time, my most recent I got 51, 53, 54. And once the car finished it’s bog it returned to 00. I also remember getting 41 and 35. At this point I think I’ve gotten almost half of the error codes pop up and disappear. And fuel pressure rises 1to1which codes?
Haven’t done that yet, I checked my fuses a while back that’s really it. But the car hasn’t been sitting for long as of recently, it’s been my everyday driver for 4 years now, if any of the rat shit is still on the car id be surprised. I’ve cleaned it inside and out pretty thoroughly multiple times. I haven’t checked ALL the connections in the car, but I haven’t found any corrosion or rust in the ECM connections. I’ve gone ahead and looked at the diagram on gnttype.org and tried wiggling every relay trying to get the car to bog but alas, nothing. Only happens when I’m in gear driving around where body shake is at its max.When the car was returned to the street, did you find any mouse/rat shit, anywhere?
Have you looked under the dash, inspected the wiring, cleaned the connections?
Have you pulled the main body plug at the fuse panel/firewall, and checked for corrosion, etc?
CODE 51- MEM CALPAC errorDifferent codes each time, my most recent I got 51, 53, 54. And once the car finished it’s bog it returned to 00. I also remember getting 41 and 35. At this point I think I’ve gotten almost half of the error codes pop up and disappear. And fuel pressure rises 1to1
Your definitely loosing power to everything intermittently!Haven’t done that yet, I checked my fuses a while back that’s really it. But the car hasn’t been sitting for long as of recently, it’s been my everyday driver for 4 years now, if any of the rat shit is still on the car id be surprised. I’ve cleaned it inside and out pretty thoroughly multiple times. I haven’t checked ALL the connections in the car, but I haven’t found any corrosion or rust in the ECM connections. I’ve gone ahead and looked at the diagram on gnttype.org and tried wiggling every relay trying to get the car to bog but alas, nothing. Only happens when I’m in gear driving around where body shake is at its max.
Your problem wasn't the coolant sensor. And I think it just got worse.Well, after months of trying different things, installing a new coolant sensor seemed to do the trick. It makes absolutely no sense to me and it’s honestly the last thing I’d think of. It no longer has the check engine light misfire problem, scanmaster reads no malfunction codes which is satisfying, and it’s been running very nice with those 60 lb injectors + Turbo Tweak chip. I’ve been driving it to and from work for about 2 days now. However I started it up earlier, and as I was waiting for it to warm up and it sputtered and died right there in my driveway. Turned it over again and it died almost immediately. Then it wouldn’t turn over at all. I thought I ran out of gas or something. But I let it sit for mabye an hour and it turned over and idled like nothing happened... Odd... with the problem I was having before the car wouldn’t die, and now it is dying, with completely different symptoms. Sigh.
I believe you are still loosing power to something intermittently, but maybe more frequently and for longer intervals. Maybe start thinking about it being an ignition module.
Either way, I wouldn't trust it outside of the pushing distance from your driveway.
I replaced all my fuse links, and I’ve also replaced my ignition module 3 times already. Gone through with plugs and wires, coil pack, maf, new battery, and my alternator isn’t even 3 years old. It’s not cutting out rapidly anymore. I honestly didn’t think it was the coolant sensor either, but the car ran great for 2 days without a single hiccup. It only just started this last night, seems fine when the engine is cold, but as soon as it reached 170 it seemed to want to die on me, backfired a couple times while I was driving it, and then it died at a light trying to idle. But started back up and I barely got it home. I think it shut off 3 times in my neighborhood lol. Seems completely different from the problem I was having before when my check engine light was having an aneurism. Because my car never completely died before with that problem... It was always able to at least idle ok. Check engine light doesn’t even pop up anymore when it sputters and bogs with this new prob. This car is a goddamn mystery I swear
