My car is still on jack stands while I get the posi installed, rear end back in, brakes, etc... Seems to have turned into a larger project than I thought!
I will let you know but I am of the opinion that every brace imaginable needs to be put into our cars. The other braces I have done to this point have helped a lot!
I,too, unfortunately am not in a position to tell you as my car is about 3mos away from full frame off completion + ive changed so much from the last time i drove it that I wouldn't be able to single any one change out...
I just installed a set on my car. I haven't driven the car yet, but it has to help with control arm mount flex. I have the HR lower mount braces. The main reason I got these braces is for adding strength to the frame notch. This seems like the area that would flex the most.
I had the Hotchkis ones on mine (which look just like the UMI's), went to the Edelbrocks because they don't stick out as far. The Hotchkis ones hit the mufflers with a torque tech setup.
