I read through all the eDist posts I could find, but I still have a couple of questions. Most of the posts seemed to be for LT1/45 or LS1/6 engines.
I am running a FAST SEFI, WB, ICC box. Since I would be eliminating the distributor, and hence my cam signal, I know I need a source for the cam signal for the edist. I though MSD has a distributor plug that would drive the oil pump and also has a output for the cam signal but I can't seem to find it on their website. Anyone have the part number for the MSD distributor plug with cam signal output for a wet sump?
Also, am I understanding correctly that I don't need to use any kind of ignition box at all (MSD DIS, etc)? I can simply use 8 LS1 coils? So all I'd need is to trigger the eDist from the FAST "points" wire, and then the eDist would fire the 8 LS1 "coil near plugs"? Are these LS1 coils powerful enough for use on a 20-25 psi turbo engine?
How does this compare to MSD's Coil Per Plug (PN 7600) system? I don't think that system would benefit me since I already have individual cylinder control with the FAST SEFI?
