EGR Block Off / Boost Gauge Question
rphatdad
I have a turbo tweak chip with egr turned off I have the block off plate installed. I was wondering if rather than plugging the vacuum line that goes to the egr solenoid If I could just run my boost gague from there?
my thought would be that there would be less chance for leaks than teeing the map line.
There should be a check valve on the vacuum line to the egr valve.That would keep you from getting a boost signal on that line.You might want to tee in to the charcoal canaster vacuum line instead.Very easy to get to.
Yes you can do this as this is how I have mine done. And yes you do not want the line to the map sensor to break or leak especially if running an alky kit that utilizes the map sensor.
