GottaBuick
- Dec 10, 2007
I have been trying to correct all of my possible vacuum leaks on my otherwise stock gn, replacing gaskets, all tubing, etc. Well today, to check my progress I pressurized the intake track with only a couple psi, and imidiately heard a leak at the EGR, it is not coming from the base, but from around the stem. I can't tell because of the angle if it is the diaphram side or motor side. But, I am almost positive this isn't normal, is it? I can't hear any other leaks over this one and it only takes 1 psi applied to hear it. So it the EGR bad?
Thanks,
Thanks,
