EGR valve leaking at high boost
bsdlinux
Just Another BLACK Car
I've noticed a little oil around the EGR on my car. I'm assuming the diaphram is probably on its way out?? Also how much boost is the stock EGR valve designed for?
I *believe* oil gets in there from the PCV. I 've had a lot of intakes over the years with a lot of oil in the EGR passage that were good running engines. The factory design gets us agian. The oil will eat the diafram over time and do what you describe.
I usually run a powerplate and do not drill the EGR hole. I also use a PCV catch can. These work for me. And this is only my opinion.:smile:
TT chips delete the EGR so pull it off and cap it.
