Egr ?
kcs387
Can i eliminate the egr and in stall a block off plate with out doing anything to the heads or intake? Thanks Ken
Yes, When you remove the egr valve the stud will still be there. Just install gasket and plate and tighten down. You can also remove the egr solenoid and plug off vac port.
OK thanks i have taken it off and it has a cleaner look with out it i was hoping to keep that look. Thank Ken
the stud will come out easy. at least mine did some may be stuck. the block off plates come with a new bolt. also you can only take off the egr and solonoid if your chip has it disabled. eric tt chips do
