Chatmanboy
- Jun 25, 2009
Anyone running an electric fan w/o using caspers 84/85 kit, that works good? My relay keeps blowing ever since the weather crept up into the 100!
SignUp Now!Brad... i seen in one of your other post was to put " A temporay fix is to put a wire accross the connectors in place of the relay. The fans should turn on when at operating temperature as before." what did you mean by that?
Chatmanboy buy urself that 86/87 dual fan harness relay kit and install after the 84/85 conversion kit I just did it a few months ago and no problems
I got the 86/87 realy kit today. need help on how the wiring goes after the 84/85 kit!The problem is your fan or fans draws a larger load than the stock 86/87 electric fan. I had to add a second fan relay kit after the 84/85 kit in order to run my dual fans. One other solution is to get a thermostat controlled fan kit and bypass the ECM all together. Stay away from switch controlled fans because you will forget to turn it on. Brad
