Electric Fan Question
t3intercooled
K I have the fans from ATR I believe that are the dual electric fans. Now they are wired up and also wired to a switch. They work if the switch is on, however I must have turned my switch off and i pulled into the driveway and steem was coming out of my radiator cap and the fans were not on. So they are not kicking in at the temp of the thermostsat. Upper hose is Hot so coolant is circulating, It worked when I pulled the motor and now that I installed itit does not work, can anyone help me with this.
Brandon
