When the car sits for about a week, not started at all, the electrical power goes to just about zero and it needs a jump-start to get going. (interior, trunk & engine lights very dim and not enough electrical power to operate anything else) When car is driven again after only 2 or 3 days, it starts fine and there's no sign of any issues.
Car has had this gremlin for a couple years now, recently changed over and upgraded a few parts that were on the list to get done anyhow and hoped that the gremlin would be solved too.
Changed original stock alternator & starter. Replaced with 200 Amp Alternator and the mini-starter we've seen offered by a few of the vendors here.
Installed Casper's Field/Fix harness to alternator.
Changed 5 year old battery to new battery.
A couple local guys have said to let it sit another week, but this time disconnect the battery and then see if it starts fine. OK, I understand the strategy there. But that still wouldn't identify if the power loss is still happening or not and I now know that something is draining away power, pretty slim odds a new battery fails after a week.
I made sure doors shut all the way tight and verified no interior lights were still on, headlights were for certain off.
I even suspected the under-hood light might have been the problem and had removed that bulb before letting it sit this time for the past week.
Anyone run across this issue before?
Any opinions on the most likely culprits?
Thanks.
Thanks.
