Trying to troubleshoot why fans come on with key, before start, only when engine is at operating temperature. Blogs/manual point to coolant temp sensor (replaced) and in some cases chime unit under dash (replaced). Odd thing is that the fans can be triggered off when accelerator is depressed (engine off). Running a FAST, and the radiator fans are turned on and off at correct temps. Have the full manual, but cannot locate any relevant information. Hoping that someone else had this, and found a solution.
