Electrical gremlins in the lighting.....
kh440
Jo Bu needs a refill!
Here's what happening: With the headlights on the right turn signal indicator in the dash stays on, signal works normally. Here's where it gets strange: With the right turn signal on the high beams dimly flash on bothe sides. Left signal: high beams glow dimly but don't flash. WTF?
Voltage feedback is usually caused by bad grounds....check all the grounds going to the headlights/turn signals. There are a couple of them on the radiator support. Also make SURE all your bulbs are good and have a good connection in the sockets.
