Does anyone know the current capability the ground wire sattached to the back of the block? This is on a TTA where the 4 grounds are attached to the back of the motor. There are 8 wires from the engine harness that adapt to 4 ground wires attached to the block. I have an 8 position connector to adapt to engine harness but I'm not sure what current is running though the wires? Each terminal, in the connector, is rated at 13 Amps. Is that enough???
