electrical problems
blipmode188
Do any of these things have to do with each other, or just a BUNCH of non working stuff ?
1 )Inside under dash light passenger side does not work, drivers side does work.
2) under hood light does not work
3) winsheild wipers work, washer pump does not
4) nothing on cruise control, no dash light comes on or anything
5) radio presets, and clock looses settings after turning car off
Steve
there are TWO power leads to the radio. One is on all the time and the other one is switched. Because some radios had battery drain problems some owners would have both wires where they were switch in order to keep the radio from draining the battery (two wrongs don't make a right applies here) find where this has been changed and fix it back, it is on the clock fuse. Then go to my site Home click on "battery Drain" in the lower left. Once you get that circuit fixed it should fix some other problems.
