Electronics Project--Help spec parts?
DAILYFLOGGER
I'm crushing your head !!
Could someone please help me spec a couple of componets I need for an ultra accurate clock timing pulse circuit that I'm tring to build?
My father has a slave clock from a factory that needs a contact closure once every 60.000 seconds. I'm imagining a IC circuit for this task.
I already have and have played with a 120 to 7 VAC trans., a 7805, some caps, a 5V radioshack relay and some diodes.
I roughed in (real rough!) the circuit using two 555 timers. Good learning experince fro me but otherwise a waste of time.
What I think is required is a oscillator section (crystal?? quartz??) for the accuracy. In combination with a frequency divider/counter? I'll still want a 555 for pulse length adjustability.
If someone could please tell me if my concept is good and if so spec the oscillator section (crystal?? quartz??) and frequency divider/counter parts I would be very gratefull.
Thanks in advance. Bruce
Salvage, THANKS!
(I knew I could get you to jump in with a subject line like that.)
I checked out the link you provided and have been waiting for a reply from them. Two weeks now. I'll try again. The module looks like a winner. I'd feel a little warmer and fuzzier if their was a supplier here in the states.
Crystal Oscilator? Doable? Too complicated?
Thanks---Bruce.
Thanks again
Originally posted by salvageV6
MCM Electronics is a good US distributor for their products (Cebek).
They don't use Cebeks model numbers however. :(
Might want to email sales and tell them you are looking for an I-25 precision timer module. :)
I have bought from them before with no problems so far. :)
If you look real hard you might find the thing on their site but I doubt it. :D
http://www.mcmelectronics.com/Home/level_5.jhtml?PRODID=15640&SKUID=14885
Thanks again Salvage.
That's the breakthough clue I needed.
I will definately be persuing that.
