BLACK MAGIC RACING
formerly turbo_canuck
- Jul 18, 2001
I just came back from the track, where i was COMPLETELY embarrassed by a best E.T of 15.05 @ 89mph. The reason is as follows: I had my chip in (thrasher 92) but couldnt get past 1/2 throttle before the boost would jump up to around 15 lbs, and the car would sputter and backfire violently, sending the kr soaring to around 10-15 deg. and it seemed that after going down about 5 turns on the adj. gate, nothing was changing. So, i switched back to the stock chip, where i was able to get the boost up to 10 1/2 lbs before it started happening again. going any higher would get the same results as my thrasher, hence the 15.05 runs. fuel pressure was the reccommended 45 lbs on the thrasher, and 42 lbs on the stock chip. Running 94 0ctane pump gas, with additive. What could possibly be wrong? bad waste gate solenoid? PLEASE HELP!! CIVICS WERE PASSING ME FOR GOD's SAKES!!!
