EMERGENCY NEED DOWNPIPE
TireFryer
Boost Loading......
Need a downpipe by early June. Need the car for my wedding on the 21st. Internally or external gn1 style. I’m on a budget..
If you get an external wastegate syle pipe do you need a provision for a wastegate made into it?
GN1 sells them with and without a wastegate provision. Sending you a DM.
Ive got a gn1 style external. Currently no wg on it but I do have e an old one i can send with. Also has a hole piloted for wb 02 but haven't welded bung to it yet. Will come with as well.....
I have an internal was that terry Houston downpipe that I never used - it’s for aftermarket headers also. I’m from michigan also where are you at?
Near lansing, is it a 3" pipe? What are you asking for it?
Yes it does s 3inch - I also have 2 test pipes - one with a cut out and one without - I’m in northern macomb county btw
