Engine bay black paint code?
V6UnderPressure
The Artist FKA Scott4DMny
I've read alot of threads trying to find a close match to the factory paint. I need to paint a core support. Eastwood underhood black is too satin, and the closest thing I've ever used is rustoleum satin. But is there no actual gm paint code for these things???
I always use krylon BBQ & stove paint. It's not flat but around a Simi gloss. I use it for trim and everything under hood.
Nope.......just a standard.
20 to 40 gloss @60° GM 4350M
I like to look for solvent resistant paint usually engine paint. I had repainted the radiator hold down very nicely, and it got sprayed w/ fuel from the rail and it was ruined. A lot of paints from the can are not solvent resistant. just something to keep in mind.
I always use black epoxy primer tuff stuff drys semi flat
You still painting stuff ronnie?
Not yet, but I will again. I've got some houses to sell, and then we are going to move and I'll set back up for custom work. friends and family.
