So as per my earlier post, my suspected headgasket turned out to be not. When I disassembled the valvetrain I found that the intake valve seal was ripped on #3, probably introducing oil to the chamber and causing the mess on the piston, etc. Burn looks OK otherwise.
However, 2 questions remain: why is compression low on 1 AND 3, and why is the turbocharger wheel so white?
Any thoughts?
Any thoughts?
