You'll need to monitor voltage on the line that feeds power to the pump. You'll find it back behind the gas tank. You could pressurize the hobbs switch that activates the boost-a-pump with compressed air. When you do this,you should see the voltage to the pump increase. The boost-a-pump is not my preferred way to increase voltage to the pump because it only increases pump voltage. If it functions properly,it's not your problem and you can continue using it for now. I would install a hot wire kit to the pump and install a volt booster. If you bought a volt booster from Dave Husek,the voltage to the computer and ignition would be increased also and the devise only weighs a few ounces. You do need to monitor fuel pressure to know where you are. If fuel pressure rises from its base setting indirect proportion to boost,fuel flow is not your problem. The first thing to check is your positive battery cable next to the downpipe. It will be easy to tell if it's been in contact with the downpipe. There is a possibility that voltage drops to zero when the boost-a-pump is activated. You'll be able to figure this out when you test it.
