turbocaddy1982
- Sep 10, 2005
my gn hiccups at just above idle when accelerating, like a engine miss only at that same flat spot, no check engine light, but when I replaced the tps sensor and went to adjust it, i notice several things wrong, i could not get the tps down passed 1.14 even with the adjustment all the way down, then 3 codes came up,1)21,tps voltage high..2)22,fuel cutoff relay circuit open or short to ground...3)43,esc module or sensor problem...
the fuel cutoff is what it feels like when it bucks...any ideas?...any wiring diagraghm that i can download and trace?
thanks
al
thanks
al
