Just got the motor back in after almost a year after having popped the ol HG,
and now the idle is all over the place, now in my smartness I installed my cracked drivers side manifold instead of the other uncracked one, hey its been almost a year, and I also removed my 83lb injectors and installed my 009's , now my modded ECM should work for both injectors, correct?? and also had the heads redone at the same time, so why is my rpm's at idle up to about 15-1800rpm then drop down to almost dying then repeat the process all over, under throttle she seems to run out well, so looking for some help
here and some ideas, thanks.
Ron
Ron
