Thanks Michael,
Used a friend's t-Type and discovered you must leave the key ON to maintain pressure in rail, so fuel appears not to be the problem.
Spray some starting fluid in, not even a little pop so on to coil pack however both (had extra one) showed infinite resistance across terminals,
pulled pack, the ignition module is gooey, understand that's bad.
So need to order a pack and module, have located a Delphi module and NGK pack.
Any thoughts on that combination?
Delphi also makes a pack so may order both from same vendor. Or if another recommendation is offered here I will follow.
Car is just used as a driver.
What's with the cream cheese frosting! Some make fun of the Advance Auto modules but have been running the same one for 13 years and lifetime warranty if needed. Picked up the coil pack also back then for $65 to have a spare but still on the original one. Just make sure you take the old one with you if you go that route because they have another similar to it. 99.9% sure they'll need to order it for you.
