Jun 2, 2012 #1 T Turbo z28 Member Joined Sep 10, 2011 Messages 132 Is it possible to get engine knock at 10psi at part throttle with alky set on 6 or is it false knock?
Jun 3, 2012 #2 Jerryl Tall Unvaccinated Chinese Guy Joined Dec 14, 2004 Messages 9,644 Turbo z28 said: Is it possible to get engine knock at 10psi at part throttle with alky set on 6 or is it false knock? Click to expand... It is entirely possible that it is real detonation at 10 PSI . . . .
Jun 3, 2012 #3 F forzfed Member Joined Oct 8, 2002 Messages 822 What are you running for an alky system? What pressures does it run at? What's done to the motor, what size turbo? Regardless that, your probably getting rich knock. You shouldn't be using alky with 10 psi of boost.
Jun 3, 2012 #4 T Turbo z28 Member Joined Sep 10, 2011 Messages 132 Im running Razor's system, I have it set on 6. Ported Stock TTA heads, 212/212 roller cam. TE 62 turbo. I have the alky set to come on at 9psi
Jun 3, 2012 #5 M mikestertwo Well-Known Member Joined Sep 13, 2006 Messages 5,249 Do you have a PL file we can look at?
Jun 14, 2012 #6 T Turbo z28 Member Joined Sep 10, 2011 Messages 132 Thanks for the replies, ended up being the knock sensor was way too tight.
