chrisgarrett
Registered Member
- Jun 2, 2004
I'm looking for suggestions on the best way to remove an engine. Each time I have removed/installed an engine, I'm not happy with the way the I end up attaching the chains. I want to remove and install an engine without removing the top end stuff. I like the idea of a lifting strap, but I don't see where you slide it under the intake manifold. Do you have to remove anything? The only space I see in the intake seems too far back and looks like it would cause the engine to pitch forward. I also don't have any lifting hooks on the intake.
Any suggestions on the best place to attach a strap or chains to the engine.
