May 21, 2002 #1 P PaulRV6 Active Member Joined May 25, 2001 Messages 1,540 I forgot to mark which mount goes where. One is 25504647 LH & 1248718 RH. Which goes on which side? Thanks paul
May 21, 2002 #2 S Sleeper Member Joined May 24, 2001 Messages 894 Paul Right 1258718 Left 25504647 Paul
May 21, 2002 #3 A arista5 Sold, and Replaced Staff member Joined May 24, 2001 Messages 1,802 they only fit one way from what i remember take one off at a time and replace it with the identical one. if the other answer was not simple enough
May 21, 2002 #4 P PaulRV6 Active Member Joined May 25, 2001 Messages 1,540 My only problem is I am not sure which side R & L is referenced from, is it while sitting in the car or facing the car from the front? I always confuse the refernce point. paul
May 21, 2002 #5 Z zam70 ->ROGUE Joined Aug 6, 2001 Messages 2,731 side designations are always from the drivers seat.
May 21, 2002 #6 P PaulRV6 Active Member Joined May 25, 2001 Messages 1,540 OK thanks. Left is always driver side. Right is always pass side. Geeeez, how can I keep this straight. paul
