I just completely rebuilt my engine in my 87... new bearings, rings, pistons, valve springs etc I installed a 212/212 comp cam in it. My problem is, I started the car, after priming everything, and it had a VERY strong valve train noise. I figured it was because the lifters werentt pumped up full, so I ran the car and broke the cam in, and the noise didnt go away. So i figured, off chance I had a few collapsed lifters, So i replaced them and its still doing the same thing. I have Reds 93 chip in it, and when i look at the scanner, I have the timing at 32 degrees, I cant remember if this is normal or not. BUT i do have a code 43 showing up, im assuming it is because of the noise. I'm at a loss here, I don't know what else to look for. Any suggestions?? I pulled the valve covers and its pumping oil strong, 50 lbs of oil pressure cold, and goes to around 15-20 lbs when it gets warm. The car idles great, the little roughness from the cam, but has NO power at all... boost wont build past 5 lbs, wont even spin the tire.. I didn't want to take it for a drive incase I would damage something ... any suggestions?????
