Chris Hogeland
TWISTED 6 RACING
- May 28, 2006
Just got done with this one. He wanted some pic to see. All I can say is its going NorthView attachment 165456
View attachment 165458View attachment 165458
SignUp Now!Yes. I do that on all my engines now.Looks good. Did you do the threaded freeze plug hole machining?
Thanks Guys.Nothing like pics of a fresh rebuild. Too bad we have to muck them up by starting them. That's artwork right there!
Yes. I do that on all my engines now.[/qu nice job thanks
Yes. Stage 2 blocks have way to many holes in the deck. I plug the ones I don't use. and if you lift the head thats the first place you would get water in your cylinders.Chris,
You do really nice work! I see you guys welded up the steam holes in the deck surface. Are you trying to get more uniform coolant flow around the cylinders or?
Neal
turbofabricator said:Nice work. Have yo used that oil pump cover before? If so, how do you keep the oil pump primed? It looks like all the oil will drain out of the pump after shut-down. I used the TA pump cover and had to modify it to bypass morre oil. I was making 125+ at idle. Blew an oil filter o-ring out at 1800 RPM. The bypass circut wasn't quite right. (Mike has fixed that issue now).
