I recently removed and tore down the engine from my 85 T type. I found that not only was it not the original block, all the info I've found points towards it being a non-turbo block (not sure that there's any difference anyway). The bore measured .030 over and there was some damage near the bottom of the #1 cylinder.
I've found a std bore 109 block that needs a rebuild. I removed this engine myself at my previous job, so I know it's a good rebuildable shortblock. I would like to go ahead and convert my hot-air car to intercooled as well, but that's a whole different thread.
What I would like to know is where to go for good rebuild parts? Who sells parts in kit forms with good pistons, etc. Any recommendations for particular pistons, rings, bearings, cam, etc would be much appreciated. Thanks!
