alliedmike
2 Cyl short NO PROBLEM
- Jun 9, 2009
Hey guys, i have an 84 gn with a turbomotion v2 intercooler setup. i found out today that i have some serious issues with compression. long story short i was having issues with low vac at idle and not being able to boost much. today in my garage i was boosting and it was having a VERY hard time getting up to boost. FINALLY i got up to 2 lb boost and No lie!! i got quite a bit of oil that squirted out of the dip stick!!
So i put a cylinder leak down tester on the engine and could not keep pressure in the cylinder and as i turned the pressure up 35 psi on the leak tester i heard gurgling from the dip stick tube and once again here comes the oil!! so needless to say i am going to be pulling the engine and doing a rebuild..i need some ideas/opinions and options on what to do. If i am in here allready do i replace pistons/ rods ect??? i do not want to go Crazy..but i do intend on keeping the car for a long time and some more mods will follow in years to come , i just want to be sure that i make this rebuild last. so any ideas on what parts to use would be greatly appriciated thanks for the help guys!!
Mike
Mike
