I do not know proper lingo - so..... I am rebuilding the engine - many of you know the saga - long story short - torqued main bolts, rod bolts, etc and now the engine will not turn - heads are not on yet - when you loosen the bolts to hand tight you can turn the engine by beating the end of a ratchet connected to the crankshaft nut - how difficult should it be to turn the engine using a standard 3/4" ratchet - new bearings, etc. all pistons and rods turned the right direction and in the right places - Please Help!!!!!
