Question. This all starts a couple of days after a successful trip to the track.
I go to start the engine, it fires and revs up a little then dies just like you turned the key off. I try to start it again and it does the same. I gave it some AE fuel and it kept running but stalled out when I put it in gear and basically didn't feel right. It continues to do this erratically.
Last night at the track. I fire it up and it does it again. I restart it and get it off the trailer fine. I go to tech and after tech It does it again. This time there is nothing I can do to try to keep it running. It fires and immediatley stalls. I can not keep it reved up either.
I get a tow back to the trailer and start checking connections under the hood, wiggle the connectors on the ECM and then she starts up, idles fine and moves on to make a 10.41 pass.
The thing that bothers me is I do not really know what was wrong, but I figured this is the way it the FAST operates when there is a problem.
Craig, what could this be? I don't want this to happen in the staging lanes
