Ideally,you don't want to control engine rotation at the front of the engine with any device including engine mounts that transfer vibration to the frame.The weaker the block,the more you want to avoid doing this. Our blocks definitely fit into the weak block category. Under hard acceleration,the transmission is exerting a counterclockwise rotational force to the back of the engine block when viewed from the front of the car. If we stop this force from rotating the block,at the front of the block,we are twisting the block like we do when we ring out a wash cloth. The way to reduce this stress is to stop the rotation of the block at the back of the block.The RJC engine brace does this. Some of the people who try to get as much as they can out of their weak Oldsmobile blocks run stock engine and trans mounts with a midplate between the block and trans to control twist. It take stress of of the engine block and allows them to produce more power without breaking their blocks. You never want to use a rigid trans mount for sure. It will break the transmission housing.
